Civil 3D Forum
Rendering Camoflage
6 REPLIES 6
Joe-Bouza
301 Views, 6 Replies
Rendering Camoflage
I amd trying to render a building  I placed on my site and apply a camoflage paint to it. I got a camoflage bmp file to use in the materials dialog, the swatch looks good but i applies it in streaks. Does anyone know how I can get a good camoflage material created to aplly to my building?
Joe Bouza
6 REPLIES 6
jmayo-EE
in reply to: Joe-Bouza
I haven't done this in a while but a few questions.
Does it look correct on the other two sides?
What is the bld modeled with? c3d srf, acad solids? Are those two walls part of one object?
If it's one object have you tried using materialmap to reset or change the map shape to box? If so and this did not work I might try rendering the bld walls separate.
John Mayo
Joe-Bouza
in reply to: jmayo-EE
No
The building was made from press pulled rectangle and the roof an extruded triangle
Tried box, planer, etc all NG
Smiley Sad
Joe Bouza
jmayo-EE
Throw a few faces on one of the walls and see if that works better.
John Mayo
Joe-Bouza
Sorry for the logn delay.
How do I throw a few faces on it?
I tried a bunch of things ; difirent object type, planner surface, .... but I keep getting stripes. something must be housed up in the file; if I make a mesh cube in a blank drawiang I get this: maybe I'll make the building in its own file a ref it in
Joe Bouza
jmayo-EE
That is a good solution.
As for the faces, type 3dface into the command line and draw a 3d face on top of one of the wall faces. Repeat for each wall. Do this in 3d view of course. I think the faces render materials better.
John Mayo
AllenJessup
Yes. I was going to suggest a Mesh. But I see you've found that out already.
Allen Jessup
CAD Manager - Designer
Rail Community
