Civil 3D Forum
Rendering and Visualization of Corridor-Which method is better?
1 REPLY 1
259 Views, 1 Reply
Hi folks,
My knowledge is that there are two ways of rendering and visualizing corridor. One by Code Set Style; the other by Corridor Surfaces and Corridor Surface boundaries. So, what are the advantages of one over the other? Which method is more preferable?
1 REPLY 1
tcorey
Use of the Code Set Styles allows you to render different parts of your design (asphalt, curbs, shoulders, etc.) differently. If you make a corridor surface, that entire surface has one render style so you would need to make a separate surface for each part of the corridor if you want differentiation.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
