I'm not getting any hits that are current on this. How do I rename or delete a data shortcut folder?
C3D still sees the original folders and names after deleting or renaming them using Windows Explorer.
Solved by Jeff_M. Go to Solution.
Solved by Neilw_05. Go to Solution.
I now know the solution. We have to select another working folder to force C3D to refresh the shortcuts.
Yes that does work as well. In any case a workflow should be included in the help documents.
