I want to remove the right label - upper on the curb. I want to have only left and right for the road (-3.00 and +3.00). And maybe I shall add crown label - but do not have crown in the list at the left side of the print screeen
Solved by tcorey. Go to Solution.
I'm not sure why that curb label is showing up when the only point that has a label style assigned is ETW. Maybe that point has the wrong point code assigned? I would have to see the drawing so I could more closely inspect your code set style and your subassemblies.
Regarding the crown point, look at the properties of either the right or left lane. There will be an option for Crown Point on Inside. Turn that option on. In the code set style editor you might have to Import codes (the button bottom right) and pick the newly changed lane subassembly on the screen.
Tim
Thank you Tim!
I think the point is not on the back side of the curb - but the begining of the sidewalk.
If you wish send me PM with your email to send you the file.
BR
Dimitar
my email address is not private:
tcorey at shasta dot com
or if you prefer the long version: support at deltaengineeringsystems dot com
Feel free to send your file and I'll take a look.
Tim
Hello Dimitar,
In looking at the Assembly called NP duqsna K dolu, I found that just to the right of the small curb subassembly is a small LaneInsideSuperVaryingWidth. The leftmost point of that subassembly has a point code of ETW. This is hard-coded into the subassembly and cannot be changed
The workaround would be to use a different subassembly (or a combination of subassemblies) instead of the one you are using now. Finding one that allows that point code to be changed would allow you to not label that point.
Best regards,
Tim
Thank you a lot Tim,
obviously I have to change this LaneInsideSuperVaryingWidth subassembly, because besides this ETW code - when I try to compute the material list its layers are not there. Dont know why!?
Thanks one more time!
