What is the correct way to remove SE from any given curve on an alignment? I have calculated and the angency does not want SE on a particular curve.
Joe Bouza
Solved by MikeEvansUK. Go to Solution.
In tabular curve editor, select the curve to remove, then the first transition in regionand click delete.
Note it does not dissapear?? Bug?? Next click Ok and exit then re open the tabular editor it should have now gone.
This means that you should have defult values (from sub assembly) before this range. I usually would prefer to edit the curves values and change to normal gradients instead as it may play up using the delete method.
The other way could be to export the SE info and adjust it in Excel then bring it back in.
Hope it works Joe.
Thanks mike I'll give it a try
Joe Bouza
