Civil 3D Forum
Remove Super Elevation
4 REPLIES 4
Joe-Bouza
4718 Views, 4 Replies
What is the correct way to remove SE from any given curve on an alignment? I have calculated and the angency does not want SE on a particular curve.
Joe Bouza
4 REPLIES 4
MikeEvansUK
in reply to: Joe-Bouza
In tabular curve editor, select the curve to remove, then the first transition in regionand click delete.
Note it does not dissapear?? Bug?? Next click Ok and exit then re open the tabular editor it should have now gone.
This means that you should have defult values (from sub assembly) before this range. I usually would prefer to edit the curves values and change to normal gradients instead as it may play up using the delete method.
The other way could be to export the SE info and adjust it in Excel then bring it back in.
Hope it works Joe.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Joe-Bouza
in reply to: MikeEvansUK
Thanks mike I'll give it a try
Joe Bouza
open tabular editor, on top right hand corner click on the icon saying "clear all super elevation data."
Koki4
Thank you.. good way ,I wanted to start from scratch ..
Rail Community
