I have an existing topo surface. Within the perimeter of that existing surface I have an area of proposed surface which blends into the existing. I now want to create a pipe network which will start at a point below the existing surface (outside the perimeter of the proposed surface) and extend under the proposed surface. When I create the pipe network, it appears I can pick only one surface to associate with it. How do I create one surface from both the existing and the proposed and have the portion of the existing surface that lies within the proposed removed?
TIA
Wil
Solved by wfberry. Go to Solution.
You need to make a new Surface.
1. Paste the exisiting into the new surface.
2. Paste your proposed surface into the above.
The order is important, last in takes precedence.
Bill
add a hide boundary
Joe Bouza
