I am using Rel 2013 C3D
My question is. How do I remove excel data links from my Reference Manager (see attached image). What I have been doing is AutoCad erasing the graphics from my drawing but the link still remains in the xref manager window.
Any help is appreciated.
Type in DATALINK. Right-click on the datalinks and select Delete.
Something abu=out dictionary edit.....I used this post some time ago with sucess
http://forums.augi.com/showthread.php?78139-remove-data-link-from-drawing
Joe Bouza
Working in C3D 2013...the dxedel did not work. Links still listed in Xref manager and not able to be removed, detached, etc. No data tables exist in drawing. Are there any other solutions to this issue? Any help would be appreciated. Thank you!
Sheril
Joe Bouza
I am having the same issue. I have done everything you have. I have tried everything from DXFOUT, to wblock, purge, audit, etc. No avail, any others out there have any suggestions?
Hello.
If the drawing is not very complicated (multiple layout tabs), you can open a new drawing and then wblock your current problem drawing into the new drawing. The only items that can be copied have to be On, and Unlocked.
Best wishes
Nonbeard 13
So easy yet so hard.. for those of use that never use datalinks. Thanks only took 6 different posts to find the right answer 🙂
If you still have the linked Table, begin at step 1. If you have deleted table using delete key, go to step 4.
If all else fails, check out this thread: https://forums.autodesk.com/t5/autocad-lt-forum/data-link-manager-can-t-delete-an-excel-link/m-p/626...
Just downloaded and used the DXEDEL command and just wanted to pass along that it is still working great for AutoCAD 2021!!!
I have searched for many years for this type of command to remove unwanted missing excel links!!
Thank you for posting!!!
Thanks!!!
JRR.
Thanks!!!
JRR.
