Civil 3D Forum
Remove Educational Watermark
7 REPLIES 7
Message 1 of 8
3159 Views, 7 Replies
I have tried several times to do a clean uninstall to remove the educational version of Civil 3D 2012 so I can install the commercial version I purchased.  I have tried several times (4) to no avail.  Any ideas on how to remove the educational watermark?
Rune
7 REPLIES 7
Message 2 of 8
jmayo-EE
Are you getting the stamp in new files? It cannot be removed from existing files. If you are getting it in new files and you did a clean uninstall, you may have to begin with a new install of the OS.
John Mayo
Message 3 of 8
mathewkol
Uninstall EDUCATIONAL version of AutoCAD.
Install COMMERCIAL version of AutoCAD
The software will still be in in EDUCATIONAL mode.
Uninstall the software again.
Remove .data file
Windows 7
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data_backup.001
Windows XP
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data_backup.001
Install COMMERCIAL version of AutoCAD.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 4 of 8
jmayo-EE
in reply to: mathewkol
The OP would be wise to try your method before wiping the OS.
Thanks Matt.
John Mayo
Message 5 of 8
thepworth
Best bet is to contact Autodesk as a support request from your purchase - they will create a custom script routine for your machine to delete the watermark.  you'll need to supply a list of the affected drawings for incorporation into the script.  the watermark gets burried deep, so this would be easier than uninstall/reinstall.
from a former reseller A/E....
Best of Luck!
Message 6 of 8
DarrenP
in reply to: thepworth
i don't think they do that anymore
DarrenP
Message 7 of 8
thepworth
It's how we were directed to respond as of a year ago, don't know the latest, but it would be my first thing to work with since I've seen install/uninstall not work (but didn't edit/delete the file recommended in previous posting).
Happily (or not) on the other side of the fence as a "user" or member of the "flat forehead society" again 😉 ...
Message 8 of 8
Yong.Jing
There are several things need your confirm:
1, which kind license do you have? Commecial or Education?
2, during the uninstallation, have you delete all files, especially the template. They might have education wartermark.
3, does this dwg create or edit by autodesk software which has education license, then transfer to you?
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Rail Community
