rkmcswain
Message 11 of 36 (1,741 Views)
Re: Remove .DST's from Recent Documents list
09-25-2012 05:54 AM in reply to: Jeff_M
Jeff -
I would like to add my thanks to you for this tool also.
Unfortuntely, it just defies logic that we even have a need for such tools though.
Why can't Autodesk just FIX this?
New Member
jarrad.fels
Message 12 of 36 (1,704 Views)
10-03-2012 04:22 PM in reply to: rkmcswain
Hi guys,
I downloaded and ran the tool on my PC, but when I go to run on another PC it fails to launch and displays a dialogue box saying "AutoCAD Recent Documents Manager has Stopped working - Windows is checking for a solution to the problem...."
Has anyone else come across this error? Any suggestions how to get around it?
By the way, we are all running the same PC's. Z400's with W7 x64.
Active Member
KEGdrafter
Message 13 of 36 (1,642 Views)
11-27-2012 10:37 AM in reply to: jarrad.fels
I too got this message trying to open the program. I also have Win7/64. If there is a way to open this program I would love to know it. I use the sheet set manager all the time and my list of recently open docs does not have a single dwg on it!!!
Jeff_M
Message 14 of 36 (1,638 Views)
11-27-2012 11:13 AM in reply to: Jeff_M
Make sure to unblock the zip file before exttqcting the dll by looking at the zip's properties. Also, the dll needs to be run from a local drive, not over the network.
Active Member
KEGdrafter
Message 15 of 36 (1,635 Views)
11-27-2012 11:22 AM in reply to: Jeff_M
I've unblocked and running locally but with no luck. Any other suggestions would be appreciated.
Jeff_M
Message 16 of 36 (1,633 Views)
11-27-2012 11:45 AM in reply to: Jeff_M
There may be an issue if you have anther Autodesk product installed which has not had any drawing opened yet. I thought I'd addressed that but it may still be an issue. I'm at Autodesk University right now so can't offer much more than that.
Active Member
KEGdrafter
Message 17 of 36 (1,632 Views)
11-27-2012 11:48 AM in reply to: Jeff_M
Jeff, Indeed I have autodesk products on board that I've never opened. I'll try your suggestion and will post back in the future. Enjoy AU! Thank you. Gary A. Tepe gt@keg-engineering.com Cad Operator - Structural Engineering Design KARINS ENGINEERING GROUP Sarasota, St. Petersburg, Naples/Fort Myers, Fort Lauderdale Voice: (866) 927-8525; HQ Fax: (941) 927-8075
Jeff_M
Message 18 of 36 (1,616 Views)
11-28-2012 10:49 AM in reply to: KEGdrafter
OK, I did make some changes to the code after the one I posted to this thread. I posted it elsewhere and forgot to add it here. So here is the updated program, and should be the one that works even when it encounters uninitailized Autocad programs & profiles.
Hopefully this solves the errors reported above.
Active Member
KEGdrafter
Message 19 of 36 (1,609 Views)
11-28-2012 11:58 AM in reply to: rkmcswain
Jeff - just tried the new tool and an extra message "a problem locating initialized autodesk applications was encountered exiting" comes up before the other message of the program has stopped running. So still no luck for me.
Jeff_M
Message 20 of 36 (1,602 Views)
11-28-2012 02:41 PM in reply to: Jeff_M
Ok, I will try to track that down when I return from AU. What other autdeak products do you have installed?
