Attached is a zip file with a standalone program to aid in cleaning up the Recent Documents list for all flavors of AutoCAD, 2009-2013.
It's pretty self explanatory, just be sure to run it with no sessions of AutoCAD, or vertical products, running. It should refuse to run if it sees any Acad.exe application in the running tasks list. Once the dialog opens it will show you all of the Autocad related products you have installed, select one and it will fill in the first list of recent documents. Then select a profile for that product and the second list will populate with the SSM related recent documents saved for that profile. You can then select any item from either list, if the same DST filename exists in both lists it will automatically select them both. Use the standard selection methods to select more than one (shift-click, control-click, window).
Be sure to Unblock, if needed, the zip file before extracting the exe file. (Check the file properties)
If you find it useful, or if you have any problems with this, please let me know at jeffm AT quuxsoft DOT com
Solved by Jeff_M. Go to Solution.
Works as advertised. Thanks for sharing.
Now that it's clean, I'll can keep an eye on how it adds and tracks recent dwg and dst files.
Is this just a one-time cleanup tool or does it also prevent new additions to the list?
Thanks.
Mark Green
Working on Civil 3D in Canada
Jeff, all of us who participate here are very lucky to have you around. Thanks for sharing this and for your on-going help.
Tim
Jeff -
I would like to add my thanks to you for this tool also.
Unfortuntely, it just defies logic that we even have a need for such tools though.
Why can't Autodesk just FIX this?
Hi guys,
I downloaded and ran the tool on my PC, but when I go to run on another PC it fails to launch and displays a dialogue box saying "AutoCAD Recent Documents Manager has Stopped working - Windows is checking for a solution to the problem...."
Has anyone else come across this error? Any suggestions how to get around it?
By the way, we are all running the same PC's. Z400's with W7 x64.
I too got this message trying to open the program. I also have Win7/64. If there is a way to open this program I would love to know it. I use the sheet set manager all the time and my list of recently open docs does not have a single dwg on it!!!
OK, I did make some changes to the code after the one I posted to this thread. I posted it elsewhere and forgot to add it here. So here is the updated program, and should be the one that works even when it encounters uninitailized Autocad programs & profiles.
Hopefully this solves the errors reported above.
Jeff - just tried the new tool and an extra message "a problem locating initialized autodesk applications was encountered exiting" comes up before the other message of the program has stopped running. So still no luck for me.
