919 Kudos
Post 1 of 43
Remove .DST's from Recent Documents list
3326 Views, 42 Replies
07-22-2012 09:41 AM
Attached is a zip file with a standalone program to aid in cleaning up the Recent Documents list for all flavors of AutoCAD, 2009-2013.
It's pretty self explanatory, just be sure to run it with no sessions of AutoCAD, or vertical products, running. It should refuse to run if it sees any Acad.exe application in the running tasks list. Once the dialog opens it will show you all of the Autocad related products you have installed, select one and it will fill in the first list of recent documents. Then select a profile for that product and the second list will populate with the SSM related recent documents saved for that profile. You can then select any item from either list, if the same DST filename exists in both lists it will automatically select them both. Use the standard selection methods to select more than one (shift-click, control-click, window).
Be sure to Unblock, if needed, the zip file before extracting the exe file. (Check the file properties)
If you find it useful, or if you have any problems with this, please let me know at jeffm AT quuxsoft DOT com
I'm glad a few of you have found it useful!
Posting an updated version of the program. Thanks to Ralph L., who located the problem with the code not working on some computers. This version should now function correctly for all users.
474 Kudos
Post 2 of 43
Re: Remove .DST's from Recent Documents list
07-23-2012 05:25 AM in reply to: Jeff_M
Works as advertised. Thanks for sharing.
Now that it's clean, I'll can keep an eye on how it adds and tracks recent dwg and dst files.
76 Kudos
Post 3 of 43
07-23-2012 05:39 AM in reply to: Jeff_M
Awesome, awesome, awesome! Thank you!
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
245 Kudos
Post 4 of 43
07-23-2012 07:40 AM in reply to: Jeff_M
Very nice of you Jeff. Thanks a bunch.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
919 Kudos
Post 5 of 43
07-24-2012 01:18 PM in reply to: Jeff_M
267 Kudos
Post 6 of 43
09-21-2012 01:55 PM in reply to: Jeff_M
Is this just a one-time cleanup tool or does it also prevent new additions to the list?
Thanks.
Credit where credit is due! Give kudos or accept as solution whenever you can.
919 Kudos
Post 7 of 43
09-21-2012 02:17 PM in reply to: troma
It does not prevent them from being added. Run it as often as you like to cleanup the list(s).
267 Kudos
Post 8 of 43
09-24-2012 06:57 AM in reply to: Jeff_M
Very cool, thanks!
308 Kudos
Post 9 of 43
09-24-2012 08:13 AM in reply to: Jeff_M
Jeff, all of us who participate here are very lucky to have you around. Thanks for sharing this and for your on-going help.
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
245 Kudos
Post 10 of 43
09-24-2012 08:23 AM in reply to: tcorey
Absolutely.
John Mayo, PE
IDSP 2014
