Civil 3D Forum
Remove Curves from ALignment
10 REPLIES 10
Message 1 of 11
2876 Views, 10 Replies
I just created an alignment from a polyline with several vertices. For some
reason Civil3d automatically created curves at random points. Is there a
tool that I can use to remove these PI's and curves and just make them
straight segements?
Francisco
10 REPLIES 10
Message 2 of 11
You probably forgot to uncheck the option at the bottom of the 'Create alignment form Polyline' menu that says "Add curves between tangents".
To get rid of curves on existing alignments - Right-click on the alignment and 'Edit alignment Geometry'. When the Alignment Layout Tools appears, choose the icon that says 'Delete Sub-entity' and choose the ARC portion (not the straight portion). It will make your lines into a no curves alignment after you press enter.
HTH,
Rick
Message 3 of 11
Thanks Rick. Yeah that was definetely
it.  Is there a way to remove these curves without redefining the
alignment?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
You
tangents".
To
you press
enter.
HTH,
Rick
Message 4 of 11
Not that I know of. And I'm not sure why you would not want it to redefine the alignment since the curves added stationing that was un-needed to begin with. Unless I'm not understanding completely.
Rick
Message 5 of 11
I will have to redefines them.  :(.  I
just was trying to avoid that since I have a lot of my corrdiors assigned to
it.  Thanks though.
Not
completely.
Rick
Message 6 of 11
HOLY CRAP DON'T REDEFINE IT!!!
Civil 3D's big thing is not having to redefine
things like this like you had to in LDT.
Right click the alignment and select Edit alignment
geometry.  Click the Delete sub-entity button and just start picking the
curves to delete.
Better than that, hold down the CTRL button and
pick all the curves you want to get rid of, then hit the delete
key.
Matt Kolberg
Global CADD Systems
href="http://www.gcscorp.ca">www.gcscorp.ca
it.  Thanks though.
Not
completely.
Rick
Message 7 of 11
To add to Matt's reply, after deleting the curves
you will need to join the remaining tangents. Just extend the ends of the
tangents until they meet and they will automatically join. By the way, all the
remaining tangents are still part of the alignment even though they
don't meet, so C3D knows to connect them when they come
together.
alignment geometry.  Click the Delete sub-entity button and just start
picking the curves to delete.
key.
Matt Kolberg
Global CADD Systems
I just was trying to avoid that since I have a lot of my corrdiors assigned
to it.  Thanks though.
Not
completely.
Rick
Message 8 of 11
That's why I suggested the method I did - it is fairly painless and it will automatically join.
Rick
Message 9 of 11
Crap!  I forgot that he was dealing with an
alignment from polyline.  Good catch.
Matt Kolberg
Global CADD Systems
"neilw" <nwilsonATsec-landmgtDOTcom> wrote in message
href="news:6096788@discussion.autodesk.com">news:6096788@discussion.autodesk.com
together.
key.
Matt Kolberg
Global CADD Systems
:(.  I just was trying to avoid that since I have a lot of my
corrdiors assigned to it.  Thanks though.
Not
completely.
Rick
Message 10 of 11
Thanks for all the suggestions guys.
Matt Kolberg
Global CADD Systems
curves you will need to join the remaining tangents. Just extend the
ends of the tangents until they meet and they will automatically join. By
the way, all the remaining tangents are still part of the alignment
even though they don't meet, so C3D knows to connect them when
they come together.
redefine things like this like you had to in LDT.
start picking the curves to delete.
and pick all the curves you want to get rid of, then hit the delete
key.
Matt Kolberg
Global CADD Systems
Not
completely.
Rick
Message 11 of 11
Matt may have suggested not redefining the
alignment because if it is shared through vault or data shortcuts, a new
alignment with the same name will break the links.
John
That's
automatically join.
Rick
Rail Community
