Civil 3D Forum
remove an object from a selection set
3 REPLIES 3
mikee
4018 Views, 3 Replies
How can I remove an object I just selected from a selection set?   I can't find the setting that allows this. Is it some combination of items check under the selection modes in the options menu?
3 REPLIES 3
tcorey
in reply to: mikee
Hold Shift and select the object.
This will not work if AutoCAD Map image selection setting is on. See MAPIOPTIONS command, General tab. Turn off Shift+Left Click Image Select.
If you're inside a command, selecting objects, and at the Select Objects prompt, you can type R <enter> and you will be prompted to Remove Objects. This removes them from the selection set. To go back to adding to the selection set, type A <enter>.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
mikee
in reply to: tcorey
Thanks, turning off the MAPIOPTION did the trick.
rharris83Z7U
in reply to: mikee
Thank you!!! I've been looking for this for almost 3 weeks
Rail Community
