I have a bunch of plan sheets with an xref'ed motif file. This motif file has several nested references in it. I saved the original plan sheets to new files and used the XREF Manager to switch out the motif file with a new one, with different nested references in it. I did this to avoid reclipping and rotating the new motif. The problem is that now instead of a relative path, I have a full path. I don't see how to change the current path [shared_drive]:\\09526211100\roadway\MTPLSP01.DWG to the path I want, which is .\MTPLSP01, I think.
Any ideas how to do this?
Well now, I'm not so sure about this. If the original motif was attached as a relative path, why wouldn't the new one take on the same attributes as the first? Like I said, I am using the XREF Manager and just changing the files out in the Found At field dot dot dot.
-Michael
