when the first install the infrastructure design suite untimate 2015 , the civil 3d is successful to install but it cannot show in the window desktop page and programme page. so i uninstall all of infrastructure design suite software through the Uninstall Tool. After than, i try to install once again, but the install state is showing the autocad civil is already installed. How can i fix it? Thanks
Solved by DarrenP. Go to Solution.
try using this method for a clean uninstall: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
if you are having issues reinstalling after a clean uninstall
try using this tool from microsoft
Run the Fix-it from Microsoft now.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
DarrenP
