Civil 3D Forum
Regarding civil 3D to Navisworks or frame work plus
7 REPLIES 7
Message 1 of 8
873 Views, 7 Replies
Dear sir,
Good morning.
Is that possible to convert surfaces from Civil 3D 2010 file into Navisworks format & PDS framework plus?
Or Is that possible to view in Navisworks?
GKKarthikeyan
7 REPLIES 7
Message 2 of 8
tcorey
I don't know about Frame Work Plus, but, yes, you can send surfaces to NavisWorks.
Install the NavisWorks Export utility for Civil 3D. Once installed, inside Civil 3D, have the surface displayed on the screen and type NWCOUT. This will create a NavisWorks file you can append in that application. You can also send other Civil 3D objects like corridors, gradings, pipe networks, etc.
It would be nice if we could get Autodesk to make it easier to timeline surfaces inside Navisworks. Right now you need to create many smaller surfaces in order to do this. PITA!
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 8
I tried to export autocad civil 3d to autocad 2007. But I am getting following error message.
Command: _AecExportToAutoCAD2007
ERROR: could not erase object (eWasOpenForWrite)
So, I cant able to export. Please give me a idea. I already audit, purge the drawing. But still the same problem.
Message 4 of 8
tcorey
Try using Wblock to export the objects, then open that drawing and use ExporttoAutoCAD2007.
Tim Corey
Redding, CA
Message 5 of 8
in reply to: tcorey
I tried the solution...But its not working. I am getting the fatal error. I dont know why. Is their any other solution?
Message 6 of 8
Sinc
in reply to: tcorey
I second!!!  I've been amazed for years now at how difficult it is to work with C3D and NavisWorks.  They're both Autodesk products, after all, so they SHOULD be compatible...  And I guess they are, to a limited degree.  But why so complicated?  Why all the "detail work" with an exploded TIN just to get it into NavisWorks?  Why the need to manually assign materials to individual triangles, when this has already been defined in C3D?  (Or has this issue finally been fixed in 2012/2013?)
Sinc
Message 7 of 8
in reply to: tcorey
Karthi
Message 8 of 8
tcorey
You said you have used Recover on this drawing and any Xref's that are attached?
After doing that, if the problem persists, post the drawing and one of us will take a look.
Tim
Tim Corey
Redding, CA
Rail Community
