I am labeling structures and need to use the station & offset for the street alignment not the alignment for the pipe network. It works great for the station but the offset is not working properly. It reads 0 as though it's reading the alignment for the pipe network. I've tried copying a label and adding reference text, creating a new label from scratch, putting 2 pieces of reference text in (1 for the station & 1 for the offset), and just doing the offset in the reference text instead of the station & offset...none of those have worked. I'm stumped! Any ideas what's going wrong?
Amanda
Ohio
Oh...just incase it's not clear, I'm using a structure lable in my profile view because I need to call out the elevation information too.
amanda
That worked perfectly. I pulled out the ref text and just changed in the properties which alignment and it worked great! Thanks so much!
Amanda
Dan - I had specified the alignment and the station was reading great, just not the offset. But when I tried what Steve recommended it worked just fine. Thanks so much!
