I know the xrefs will fail, but if all the drawings were originally in the
same folder and they are all located in the new folder, then the xrefs will
work. My problem is the surface reference becomes broken with no way of
fixing it.
"James Wedding" wrote in message
news:5187753@discussion.autodesk.com...
1. Xrefs ALWAYS fail if you change paths drastically, this has been the case
as long as they have been around. To achieve what you're after, you need to
be Xrefing the dwg that resides in your working folder. In your case, I'm
not clear on whether or not you changed the Xref path now that the working
folder should be the path for the Xref file.
Also, the way to use Vault from a laptop perspective is to use Offline
Folders. This preserves the drive mapping, pathing, etc., and avoids the
issues you're running into.
2. Proxygraphics are only intended for use for people that do not have the
creating software, i.e. Acad, ADT, etc can use the proxygraphics to display
C3D objects if they choose not to install the full object enabler.
HTH
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2007
XP Tablet, SP2, 2GHz, 2G
www.eng-eff.com
www.civil3d.com
