Civil 3D Forum
Reduced level claues
3 REPLIES 3
847 Views, 3 Replies
How can i create a profile using level data obtained from dumpy level with civil3D
3 REPLIES 3
troma
Have you gone through the alignment & profile tutorials?
Mark Green
Working on Civil 3D in Canada
neilyj666
You'll certainly require the Easting/Northing of all the level points obtained with the dumpy level before you can do anything
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
ericcollins6932
Assuming you want a simple profile and know the distances between your setups, reduce your data and make up arbritary xy positions for each setup into a text file
x,y,z
0,0,105.57
0,30,106.63
0,55,103.21
Bring these in and make a profile from them. Or try the following:
From the Home tab, Create Design Panel, Profile drop-down, Create Profile from File
  • Browse to the text file (a text file uses the .txt extension) created using the following format requirements.
  • Click the text file and click Open. If the file is correctly formatted, it is read into the system and the Create Profile - Draw New dialog box is displayed. For more information about correct file formatting, see Format Requirements of Profile Files.
  • In the Create Profile - Draw New dialog box, review and revise any settings you want to change for the profile name, description, and styles.
  • Click OK to save the profile in the drawing.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Rail Community
