Good morning,
The rectangle feature line , whose elevations were obtained from the surface, were then added to the surface as a breakline.
I have not even began grading the inside of this rectancle as a grade fill and this cone points out of the surface, please help.
thanks
Are there any other feature lines in the same Site? If there are and they cross this one at some point, then the intersection will be pulled to meet it.
Don Ireland
Engineering Design Technician
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Did you just get the levels from the surface at the rectangle vertices or did you get them at each triangle intersection?
neilyj (No connection with Autodesk other than using the products in the real world)
Thanks, the hole & leg value belong to the surface's edit property and I deleted it. It happened when trimming by deleting the points of the excess of a surface fill on a embankment cavity.
When looking at the image, the fill grading is 1:1 slope bounded by rectangle feature line. The feature line is also a breakline to the existing surface. I'd would like to have an additional grading on the sides of the the rectangular surface.
Secondly, I cannot bring the fill surface above the existing surface. Is a boundary on the fill surface necessary to show it or is this a drawing order issue?
Finally, when merging the fill and existing surface, how do i limit the elevation band to stay only within the fill surface boundary?
thanks again.
