Hi, I'm trying to create a surface using data that a contracting surveyor has provided to us.
He has sent me a .dxf containing all the breaklines for kerbs and edges of buildings etc, and a .csv with all of his point data, in PENZD format.
The problem is, his breaklines have been created to 4 decimal places, and his point data only goes to 3.
I start a new drawing (we work to 3 decimal places), create cogo points from the .csv, then paste the breaklines in from the .dxf, then add the breaklines to the surface.
As you would expect, every vertex of every breakline is just off the point it should be attached to, due to rounding.
Is there any way I can get these breakline vertices to physically move after truncating their coordinates to 3 decimal places, so they exactly line up with my points?
I hope I have explained myself alright.
Cheers,
Archie
Solved by Jay_B. Go to Solution.
The breaklines could be added as is as Proximity rather than Standard as the lines do not need to match the points precisely.
