AutoCAD Civil 3D General Discussion
0 Kudos
Post 1 of 4
Realisic No Edges not visible in Object Viewer
219 Views, 3 Replies
12-08-2009 05:38 AM
After I upgraded to C3D 2010 the choice Realisic No Edges is not visible in Object Viewer. Just Hidden, Wireframe, Conceptual and Realistic is visible. What can I do?
*James Wedding, P.E.
Post 2 of 4
Re: Realisic No Edges not visible in Object Viewer
12-08-2009 07:34 AM in reply to: hakangus
Have you created a Visual Style called Realistic No Edges? That's not a
default style, so someone had done that for you previously.
JW
0 Kudos
Post 3 of 4
12-08-2009 08:22 AM in reply to: hakangus
I agree with James. The 'isolines' you can turn off in the visual style. These adjustments are specific to the template you are using. You could adjust them in the template and will be set in that way every time.
Jack
0 Kudos
Post 4 of 4
12-09-2009 11:24 AM in reply to: hakangus
Thx both. I run _visualstyles to get the dialog. Then I temporarly droped the visual style Realistic No Edges to the Tool Palette from an earlier drawing. Then dragged it into my new template. Now it works fine.
Post to the Community
New Post
