Civil 3D Forum
Reading triangles from file...
1 REPLY 1
tspoon005
1935 Views, 1 Reply
Using AutoCAD Civil 3D 2012:
When I open files from a particular project, they are very slow and get stuck when AutoCAD says "Reading triangles from file...".  Eventually, after 20 minutes for some drawings, they will actually open.  This particular project uses a lot of data refs and xrefs, and has given us problems before.
Does anybody have any idea what AutoCAD might be getting hung up on?  I've started to purge and audit drawings as I go to try and clean things up, but I think its something related to Civil 3D objects (probably a surface) and would like to get to the bottom of it so that I can save some time.
Thanks!
1 REPLY 1
sboon
in reply to: tspoon005
It sounds like you have a surface in your project which is stored in an external mms file.  If the drawing which hosts that surface is xref'd into other project drawings then the program has to load the surface data for display and labelling.  If the references are nested then, in theory, you could be loading the surface multiple times.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Rail Community
