Distinguished Contributor
dwk1204
Message 1 of 4 (358 Views)
Re-Station Alignment after Editing
358 Views, 3 Replies
01-13-2013 05:50 AM
After editing an alignment in my drawing the stationing did not update to the new edited alignment. I tried selecting the alignment and in alignment properties changing the end stationing, but I get the error "Either outside alignment limits or within gap created by a station equation". The stationing stops at my first edit point 66+24 when the total length of edited alignment is 103+15. Is there a way to re-station alignment.
Thanks in advance for any help....
Joe-Bouza
Message 2 of 4 (353 Views)
Re: Re-Station Alignment after Editing
01-13-2013 06:09 AM in reply to: dwk1204
Was the alignment created from objects? I have experienced aligment problems due to acad entities being drawn in the wrong direction of the alignment.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
BrianHailey
Message 3 of 4 (337 Views)
01-13-2013 09:31 AM in reply to: dwk1204
As Joe said, make sure your alignments are connected and that they are going the correct directly. Each alignment entity has a direction assigne to it. The end of one entity must be connected to the beginning of another or the stationing won't continue. You can flip the direction of individual entities using the Geometry Editor (select the alignment and it's on the context sensitive ribbon and it brings up the alignment layout tools) and then selecting the Reverse Sub-entity Direction command.
Brian Hailey
CAD-1.com
My Blog
dwk1204
Message 4 of 4 (310 Views)
01-14-2013 09:20 AM in reply to: dwk1204
Thanks to both of you....I reversed the edited entities and the stationing updated.
