2014 Civil 3D
Windows 7 64-Bit
Oracle 10.2
"The Specified Credentials are not valid or the provider is unable to establish a connection.
The runtime was not found (module 'OCI.dll'). Please verify your oracle client component installation."
Oracle client is installed on this machine. We have tried it as a 32 bit installation and 64 bit. My system adminstrators have done their own research into this topic and found no specific examples of this issue, or similar, that would provide an answer. The documentation on this feature is severly lacking, especially the trouble shooting portion and requirements. The answer the knowledge base gives is "Yes, you can connect to an oracle database." then proceeds to link you to the article "To Bring In Features from Oracle" which doesn't address this particular error, but does have a broken link to an article that might actually be helpful, if it worked, entitled "Working with Oracle Data".
Any help in making this connection work would be greatly appreciated.
Try to copy the OCL.dll to you BIN/FDO folder.
C:\Program Files\Autodesk\AutoCAD 2015\Map\bin\FDO
Also there is a file named FdoUserManager.exe in that
folder, double click it in Windows Explorer to run it and try connecting there if you have admin name/password.
