I'm trying to insert this .tiff and it keeps dropping it at 0,0. The correlation source drop down never shows an option for world file. I have tried removing the "x" at the end of the extension and still no luck. I've attached the tiff but when i try to attach the world file (.tfwx) I get an error "The contents of the attachment doesnt match its file type." Any help is appreciated. Thanks,
cross posted on Raster Design board.
Solved by antoniovinci. Go to Solution.
here's the contents of the world file, extension tfwx
5.0242318476081875
0.024718769829332337
0.024718769828505995
-5.0242318476073056
2325843.3526948257
7017070.1109297834
Charles:
I know you showed a .tiff file but I would think that this is only a .tiff of the normal Firm Map Community sheet. The files that I have seen that use the .twf file are much larger in file size and are .tif map file.
Just one opinion.
Bill
It doesn't matter, Bill: a georeferenced image can be very small, it depends on colour depth and compression rate.
@ Charles
About your attached one, it is a true Geotiff in EPSG:2276 containing the following header:
0.00500000
0.00000000
0.00000000
-0.00500000
0.00250000
8.49750000
As you see, it sounds far away from your worldfile.
I'm glad to upload the fixed Geotiff, sir.
Thanks, I appreciate you doing that. What software did you use to edit the tiff info? Is there way to get RD to ignore the tiff geo reference and read a world file instead?
No way, sir: the header of a Geotiff gets priority on every external worldfile.
Here's my workflow to fix your damaged file:
@ Billy
Below I attach a special version of Charles' Geotiff, four times smaller than the previous one.
I've simply converted to monochromatic, upon the same high resolution, then compressed with the powerful CCITT algorithm.
