I copy a raster image from one spot in the drawing to another, use it temporarily, then I erase the copy of the raster image, it asks me if I want to detach the image, I say no, and it detaches it anyway and all copies dissapear and have to be reattached???? What am I missing?
Solved by dhenderhan. Go to Solution.
Hi David,
I tried a few things to recreate the issue, but was unsuccessful. I attempted in Civil 3D and Map 3D 2013 Suite installs and updated servive packs.
Referenced an image using Xref, copied, deleted copies, and I don't get the detach error until I try to delete the last copy.
MAPIINSERT, copied, same results as above
IINSERT [Raster Design command], copied, same results as above.
What commands did you use to attach the images? What program [Map/Civil]? Does this happen on all drawings, or just this one? Do other users you work with get this same result?
