Civil 3D Forum
Raster image detaches even if you say no
2 REPLIES 2
dhenderhan
429 Views, 2 Replies
I copy a raster image from one spot in the drawing to another, use it temporarily, then I erase the copy of the raster image, it asks me if I want to detach the image, I say no, and it detaches it anyway and all copies dissapear and have to be reattached????  What am I missing?
David E. Henderhan, PLS
Civil 3D 2023
Dell Precision 3660 - Windows 10 Pro 64-bit
Intel (R) RTX A2000
12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
128 GB ram
2 REPLIES 2
Willy_Campbell
in reply to: dhenderhan
Hi David,
I tried a few things to recreate the issue, but was unsuccessful. I attempted in Civil 3D and Map 3D 2013 Suite installs and updated servive packs.
Referenced an image using Xref, copied, deleted copies, and I don't get the detach error until I try to delete the last copy.
MAPIINSERT, copied, same results as above
IINSERT [Raster Design command], copied, same results as above.
What commands did you use to attach the images? What program [Map/Civil]? Does this happen on all drawings, or just this one? Do other users you work with get this same result?
Willy Campbell
dhenderhan
Loose nut on the keyboard. Found system setting. Planning and analysis (map) - Insert - Image sub menu - General tab - "always detach" instead of "never detach". Thanks for looking into it for me.
Dave
Drafting Manager/Surveyor
D. R. Griffin & Associates
570 E. Crete Cir., Unit 1
Grand Junction, Co 81505
(970) 245-4921 (o)
(970) 424-7702 (c)
(970) 245-4932 (f)
DHenderhan@drg-wy.com (email)
http://www.drg-wy.com (website)
Civil 3D 2023
Intel (R) RTX A2000
128 GB ram
Rail Community
