Question for someone using Civil 3D networked via LicMgr and also using Raster Design, and binding Raster to Civil 3D.
We have the client deployment set up to bind Raster Design to
LDDT, Civil 3D, and Map 3D network deployments. Performing
client installs in appropriate order (LDDT, Map3D (as applic.), and Civil 3D first) soRaster Binds to the parent product.
Problem, we're not getting Raster menu to bind to Civil 3D like
the other products. Adding the Raster (Image) .mns/.mnc does not invoke Raster Design from Civil 3D. If the deployment is taged in Raster Design for Civil 3D (i.e. the toggles you can turn off (like Arch. , Build. Syst. etc.)) why
is Civil 3D not compiling the Raster (Image) AecCo menu, and
therefor Civil 3D will not invoke menu.
I'm obviously missing something very plain, yet can'not clear my mind. Would apprieciate any suggestions?
Geoff T.
Geoff T.
Xi Computer CM-MasterCase Pro 5 tower case (Win10 O.S.)
Ten Core i9-7900X @ 3.3/4.5GHz Sealed Water Cooled
w/ Asus PRIME X299-A mobo
32GB DDR4 @ 3600Mhz RAM
SSD Samsung 850 EVO H.D.
Nvidia Quadro P2000 (span2) + 2000
3 ViewSonic VG2436wm-LED displays
