Civil 3D Forum
Random zooming to extents
5 REPLIES 5
tdrietz
956 Views, 5 Replies
My C3D 2013 just started doing this last week...  I first noticed that it would zoom to extents when I operated the center mouse button for panning.  It was random, about 1 out of every 15 to 20 pans using the center button.  Someone suggested I get a new mouse.  Still did it.
But then I noticed that it's not just the panning.  It will randomly zoom to extents when I type in a command. Earlier today, it did it when I did a REGEN, then again when I did a MAPWSPACE.
The other notable thing is that there is no "zoom" command anywhere in the command history when this occurs.
Besides changing the mice, I also tried rebooting and running a repair on C3D.  I have Win7-64.
The problem seems to coincide with when I started using Autodesk 360.  Not saying it's related, but it's fishy.
Thanks!
5 REPLIES 5
dhenderhan
in reply to: tdrietz
Double clicking center mouse button has always invoked zoom extents for me.  It does that to me too when I get to panning too quickly.  Not sure if there is a setting for it though?
David E. Henderhan, PLS
Civil 3D 2023
Dell Precision 3660 - Windows 10 Pro 64-bit
Intel (R) RTX A2000
12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
128 GB ram
tdrietz
in reply to: dhenderhan
Yes, that's why I thought it was the mouse at first.  I use the double click mbutton all the time and I haven't changed my technique.  But it will do this even after typing in a command.
BTW: you can disable the double center click zoom-to-extents by setting mbuttonpan=0.  But that also disables the center button pan function, which I can't live without.
Hidden_Brain
did you try setting UCSFOLLOW to 0 (zero)?
tdrietz
Yep, UCSFOLLOW was already set to zero.
tdrietz
Just to follow up...
In my earlier post, I mentioned this problem seemed to coincide with when I started using AutoDesk 360.
I know this makes absolutely no sense, but I discontinued using AutoDesk 360 and disabled the cloud sync.  I have not had the random zoom-to-extents issue since.  Go figure!
Rail Community
