Civil 3D 2013, SP1, Windows 7, 64-bit - I've got a user who imports points into the survey database and RANDOMLY the points will be shifted on average 27 feet in the northing and 4 feet in the easting. She notices this becuase she'll check a point and see tht the northing and easting varies from the grid northing and easting (I've attached an image to view) She will then discard the drawing and begin a new one only to import the data and now it imports correctly. The behavior is completely random and it's happening on multiple projects. All the projects begin with the same template. All the settings (drawing settings and survey settings) have been set to US Survey Foot. It's weird because once the issue is noticed it can be fixed by simply beginning another drawing and re-importing the data, but it has happened on projects where she's already got pre-existing data. Any ideas on what may be causing this?
Thanks in advance,
Jason
Sounds like you are importing them with International Feet when it should be US Survey Feet. Right-click on your survey database and select Edit Survey Database Settings. Change the International Feet to US Survey Feet. You will have to re-import the points after you fix this.
Check to be sure you have the same coordinate system selected, not just units.
Surveyor Lee
Yes, I would check the coordinate system. Here in Australia, we used to use AGD66, but now using MGA94. Coordinates in the old system are offset by approximately 150m, east and north. This used to cause all manner of confusion until people got used to it. I'm sure the same has happened just about everywhere over the world at one time or another.
I've verified all your suggestions in some of the past projects and current ones. All the settings are correct and in line with your suggestions. The weird thing. . .remember, this happens randomly. All the settings are the same throughout each project. So why does it randomly shift the coordinates? And why is it always the same (or similar) distances? Maybe it's something on our systems.
Thank you all for all your input.
Jason
I guess I'd start basic troubleshooting - is it only one file (or group of files?), is it only affecting one template? is it only one computer or all of them? etc. Is it only after a certain command (is it truely random)? Is the offset amount the same? what amount is it offset by (anything familiar?)? etc. etc. Is the offset permanent or does it fix itself later?
Are you able to post the file?
Interestingly, I had a similar issue occur on one drawing just today - I haven't had time to investigate yet, but I noticed that some drawn objects were offset in relation to the underlying Bing imagery. It might be the imagery georeferencing has been altered, or I accidently moved stuff, or maybe something more sinister like you're experiencing 😞
I'll have to do some checking on my file.
If you insert a drawing with the shifted points in to a new one created from your template and reimport the points, overwriting the old ones. Does that bring the points in properly?
What is the original source of the points? Were they ever converted from LDT points?
Allen Jessup
CAD Manager - Designer
Yes, I've started basic trouble shooting. Here are the answers to your questions. . .
I will try the suggestion of taking the shifted points and inserting them into a new one to see if that works. Now I just have to wait until the issue happens again. We're now logging events:
Thanks for all the input. If I find anything that resolves this I'll repost.
Good day to all,
Jason
Have you verified that he surveyors gathered the point coordinates on the same coordinate system? If they gathered them in one system and converted them to another, you could be getting some that are not on the same system.
Surveyor Lee
Yes, we've verified that the surveyor's are gathering the data in the same coordinate system. I forgot about the BASE command. I'll try it. But why would it suddenly change if I'm using the same template and the same computer everytime?
Jason
@PorterCAD wrote:But why would it suddenly change if I'm using the same template and the same computer everytime?
One thing that comes to mind for me would be some errant program/script that runs at startup. Maybe something prevents it from running in some cases (so there are SOME times that it doesn't change the setting). Or the intention could be to change it and then change it back--something could be preventing the change back.
When you're troubleshooting something odd like this, you have to totally forget about any notions like "it can't be that--so I don't need to check it". Check EVERYTHING even remotely related to the topic until you can reproduce the issue under the narrowest circumstances. Once you've done that, you should be able to find the cause.
Don Ireland
Engineering Design Technician
Are the 40 shifted points originally to the drawing or some of the recently inserted.
Allen Jessup
Jason, I would bet dollars to dimes this is going to be caused by the international feet vs. us survey feet issue, as stated by @ToddRogers-WPM and @SurveyorLee. I see this issue very often and aligning the survey database and drawing settings to US Survey Feet fixes the issue.
As a test, scale the points by 0.999998000004, using 0,0 as the base point. If not, if they got farther apart, then scale by 1.000002.
If one of those two factors fixes the points, then this proves that Todd and Lee are right.
Sorry for chiming in so late here. I'm traveling right now.
Yes, I agree, the shift in value does sound like an international vs. US survey feet issue. However, in my testing with the client I was working with on this topic we used the same template every time and I verified the settings were in US survey feet. In one instance the points came in correctly and in the next they all shifted.
I'm not saying that this is the solution, but in this one case we had reset the user's Windows profile and the the issue appears to have disappeared. Prior to that we repaired the software and did a clean reinstall. The reason I cannot definitively state the it was the Windows profile is because the user tested a lot of other settings prior to resetting the profile.
I agree with @caddie99, next time it happens don't close the software and immediately test in an new drawing.
Also, @AllenJessup brings up a good point. . .is the shift happening to all points in the drawing or just newly inserted points?
@ron.lang, you stated that the software crashed when closing the drawing. Do you have any/all service packs installed for your version of Civil 3D? Have you tried running a repair on the software? Have you tried resetting the software back to default settings? Have you tried using the standard Civil 3D NCS template to test?
