Civil 3D Forum
Random Daylight Cut Feature Line
6 REPLIES 6
CACavallo
513 Views, 6 Replies
For some reason I'm getting a daylight cut feature line outside my corridor which should not be there (red line).  I can't figure this one out.  My daylight fill and daylight feature lines are correct.  My cross sections through this portion of the corridor are correct too.  Any ideas?
6 REPLIES 6
sboon
in reply to: CACavallo
I'll bet that you have just installed SP 2.1  Check this thread to see my screenshots of the same problem
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Civil-3D-Service-Pack-2-1-HEADS-UP/m-p/3603678#M18472...
Steve
Expert Elite Alumnus
CACavallo
in reply to: sboon
Did uninstalling Civil 3D and reinstalling without SP 2.1 fix your problem?
sboon
I have access to another computer without the SP so I haven't tried that solution yet.
Steve
CACavallo
in reply to: sboon
I uninstalled and reinstalled and the problem went away.  Thanks for the link to the other thread.
consultora
I solved this problem, spliting the corridor between the start and end of the random daylight feature line.
sboon
in reply to: consultora
Yes, you can solve it by splitting off a new region if your corridor is finalized.  The problem is that the random feature lines appear and disappear as the corridor is edited, so you may end up with a whole lot of regions.
Steve
Rail Community
