Civil 3D Forum
Rally need help with Corridor Surface Triangulation
48 REPLIES 48
Message 1 of 49
476 Views, 48 Replies
Hello, I have strange problem with corridor surface triangulation. Maybe I do something wrong for corridor from the start? As can be seen in pics that I attached, there's some surface degradation that I can not understand. At first look everything seems ok, but when I go to Realistic Visual Style something happens :)... End when I try to render this, I get more uglyer result than this shown...
48 REPLIES 48
Message 2 of 49
1 picrture
Message 3 of 49
2 picture
Message 4 of 49
Rendered view
Message 5 of 49
BrianHailey
Add feature lines to your corridor surface and not just links.
Brian
http://www.cad-1.com
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 6 of 49
Also, in the surfaces tab, click the link where it say "Add as breakline".
Matt
Message 7 of 49
I've tried what you told, but still there's the same result... All the alignments and profiles seems to be right (or it's just me who thinks they are). My reseller said that they see everything fine, but I don't believe them ;)... I tried to attach this file here, but it's too big... Maybe someone could look at my DWG as I would send it to e-mail?
Message 8 of 49
mathewkol
If you do a quick section through the affected area does it look ok? Sometimes the shaded views don't look quite right.
Matt
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 9 of 49
I made it and sections seems very good. No crashes on surfaces, daylights comes fine with project's ground surface. If the problems is shaded views, why I get the shaded view result in my rendering? I tried to make some changes in 3dconfig, but everything what I could get from that was not only crash of surface, but also of definition sections... BUT rendering seemed the same as it was... It seems that contours (edges) for triangle surface are drawn all right, but the surface doesn't follow them the way he should.
Message 10 of 49
Picture taken after 3dconfig>Manual Tune>Enable hardware acceleration
Corridor degradation. Rendering feels the same...
Message 11 of 49
It's also interesting that it happens not only with my intersection, but with all corridor model, especially in places where are rounding of alignment.
Message 12 of 49
BrianHailey
Next thing to check is that you have the top links selected for your overhang correction in your top surface.
Brian
GEI Consultants
My Civil 3D Blog
Message 13 of 49
I did it, but nothing changed, I checked and unchecked add as breaklines, added feature lines, tried different combinations with FL and Links, but even if I leave only few feature lines for Pave1 and Pave 2 I get something wrong with triangulation...
Message 14 of 49
Any suggestions?
Message 15 of 49
Please, Help ME.
Message 16 of 49
dana.probert
If you attached a drawing to the files group, perhaps someone could dig into your file.
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
Message 17 of 49
files group? Where is it. If I try to attach my file here it sais that my file is too fat.
Message 18 of 49
mathewkol
http://discussion.autodesk.com/forum.jspa?forumID=126
Your file still may be too large for that group too.
Matt
Matt Kolberg
Message 19 of 49
ok, it's 2 mb and it doesn't fit anywhere... ;/ what should I do?
Message 20 of 49
Ok, thats a link to my file, try to download it...
If you look closely to the roundings of corridor, geometry splits near Curbs and mostly on some daylights... Different colors occur on Realistic visual style.. and on rendering.
https://dshop.diino.net/getafile/FN27CD4KSIAXV1DUY5YGG9CQYU1V9OW/ok.dwg
Rail Community
