Civil 3D Forum
Rail subassembly
11 REPLIES 11
Message 1 of 12
merus
2539 Views, 11 Replies
Rail subassembly
Hi every one
I am working on a rail project that consists of two tracks. I only found that civil 3D 2006 had a subassembly for single track. Please, any one has an idea that help solving my problem specially the question of symmetrically which will never fit if I inserted two subassemblies.
Another problem is about the dimensions of the rail section in the civil 3D 2006 Rail Single subassembly. They are in imperial dimension and I am working with metric, and when I choose this subassembly the module do not transfer them to metric value. This will affect all the corridor calculation.
Thank you.
11 REPLIES 11
Message 2 of 12
in reply to: merus
I would suggest a single subassembly. Apply the assembly to different
alignments for each rail. You will control the symmetry. Also, get your
rail Single from the imperial library or from the metric library? I have
the rail in both libraries.
Larry Bettes
ADT, C3D & LDT/CD
(all 2007 with all SPs installed)
P4 - Dual Core 3.0 GHz, 3.00 GB RAM
nVidia GeForce 6800 GS AGP - 256 MB
Windows XP Pro, SP 2
wrote in message news:5345758@discussion.autodesk.com...
Hi every one
calculation.
Thank you.
Message 3 of 12
merus
in reply to: merus
Thank’s for the replay
But,
The distance b/w center alignments is 5m, if I applied a single subassembly to each alignment there will be an intersection area. Is this area will affect the volume calculation?
For my second question, if you switch to metric library and try to add a RailSingle subassembly you will find that the distance b/w top of rail and the base of the rail (RailHeight) is 50 cm and it should be not more than 16~18 cm. if you check the visual basic module you will find in the rail details parameter that the (RailHeight) is defined as 0.5 feet and not 0.5 m.
Message 4 of 12
in reply to: merus
You're ahead of me... I know how to use 'em NOT create 'em. Someone from
Autodesk needs to chime in on this one!
Larry Bettes
ADT, C3D & LDT/CD
wrote in message news:5345832@discussion.autodesk.com...
Thank's for the replay
But,
m.
Message 5 of 12
in reply to: merus
can you elaborate on what you mean by an "intersection area"? Do you mean
at a turnout? If you just mean that the subassemblies overlap, you can
adjust the width of the ties (sleepers) and ballast so that they don't
overlap. To grade in between them, you probably want to use two different
assemblies - one that defines a marked point and one that grades to that
marked point.
The rail height is probably a bug - if you were able to track down the
value, try modifying the value and see if it helps.
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
But,
m.
Message 6 of 12
merus
in reply to: merus
I’m trying to find help concerning some points on RailSingle subassembly that are not been cleared.
I thank M. Jon Rizzo for his replay, and maybe I did not clarify the problems as now:
•The easy one is about the default rail dimensions which will not suite the metric system, and the best way to correct this is by entering in the RailSingle visual basic module and change the rail details parameters in accordance to the wanted rail section.
•The RailSlope should be determined for the slope between the ballast layer and the subballast layer. It should not be at the top of ballast, this slope should be determined by the rail superelevation. I need help for that.
•In most of rail manual, we need 25 cm as a minimum of ballast thickness under sleepers. By a small calculation if the sleeper height is 20 cm, we need around 45cm (1 ½ feet) of ballast. The subassembly does not permit a ballast thickness more than 30cm (1 foot). We can solve this by changing the default values for input parameters in the module, but the problem appears in the position of the points that have the code 7 and 10, they will stay fix with a funny cross section drawing.
•How many digits I have to enter for the subballast side slope to have a vertical slope position. This vertical subballast will help if we need to design a double track without any overlap at the intersection points.
Thanks for the help.
Message 7 of 12
jay.joshi
in reply to: merus
Hi Merus,
Did you ever find any answers to your query? We are facing the same problems with rail subassembly.
Jay
Message 8 of 12
cadtown
in reply to: merus
Multi-track railways with independent alignments, profiles and superelevations... It is also a classic example of divided highways...
There was a gentleman from Europe who deperately tried to use Civil3D for railway design without much success, and he is now one happy Section3D user who is able to do what others are still struggling with...
http://discussion.autodesk.com/thread.jspa?messageID=5733240
"Civil 3D with Section3D will be the best railway design software in the world." and I will NOT disappoint anyone who is both patient & smart enough to read my mind...
Peter,
Message 9 of 12
John7
in reply to: merus
Where do I find rail assemblies in Civil 3D 2009?
I looked around but didn't find them (including HELP).
John
Message 10 of 12
in reply to: merus
There's 1 each in the Metric & Imperial Corridor Catalogs under the
Transportation Design Subassembly sections.
Go to the General pulldown menu, select Catalogs....
"John7" wrote in message news:6297522@discussion.autodesk.com...
> Thanks
> John
Message 11 of 12
tcorey
in reply to: merus
Hi cadtown,
I checked out the .dwg you posted as an example of what can be produced by Section 3D. All i see in the drawing are cross sections, but they aren't even Civil 3D cross section views or cross sections. They are just polylines and 3D faces for frames.
Is this a design software for rail. Does it produce a corridor or just these sections? Can it produce actual Civil 3D objects or is it reading from Civil 3D and creating AutoCAD objects only?
I agree that Civil 3D out of the box is limited when it comes to rail design, particularly in lack of subassemblies. A good add-on would be of use.
Tim Corey
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 12 of 12
section3D
in reply to: merus
I think only the dwg file was posted to due the file size limit.
You should check this out:
http://www.section3d.com/Rail-Single-Track_1.html
Rail Community
