Hi, in C3D 2014 (CZ) I've got problem with inflection point. I've got a good assembly definition, but when I put cant definition to Civil, it gives me a problem with curve overlap and for corridor making CIVIL use one rail cant only. Where is defined zero cant for first rail, civil use stepwise cant value for the next rail. Subassembly rail top points are defined only from TrackWidth and Cant Values...
Have you any solutions?
Thank you
