AutoCAD Civil 3D General Discussion
Valued Contributor
Grimes_MG
Message 1 of 1 (105 Views)
Radius Dimension Missing First Arrowhead
105 Views, 0 Replies
08-16-2013 10:48 AM
First Issue: I have created a Dimension Style to dimension a circle's radius however, even though I set the "First Arrowhead" type as "Dot", it doesn't show up. My "Second Arrowhead", which is a arrow, shows on the edge of the circle, but the dot at the center does not. This is different than the "Center Marks" option, which I have set to "none" because I don't want the two options, a Line or Mark, but rather a "Dot".
Also, if the text is more than one line, it masks the dim line underneath it. Is there a way to change the draworder so the dim line is above the multi-level, mtext?
Finally, to remove the prefix "R", I would need to edit my Drawing Setting's correct?
Win7 (x64), EVGA 790i, 8GB RAM, EVGA 8800GT, 250 GB iSSHDD, & RAID 0/1
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
