Does anyone know if there is a way to set the zoom scale or magnification to apply to when you click the "zoom to" command such as "zoom to point" or "zoom to object" ?
Garry
Solved by Maine-iac. Go to Solution.
Great question, this crossed my mind today. Nothing like zooming to a point and there being 30 points in the area. It's like finding a needle in a hay stack. Setting this to zoom in further would be ideal. I'm not sure if there is a system variable but I'm posting because I'm interested in the answer as well. Thanks.
Maybe there is an answer, but if you manuall zoom to the height desired and use "Pan" to it may help zero in
Joe Bouza
I just stopped using "Zoom to" and now use "Pan to". Scroll in or out to the desired height, then use "Pan to" and it will hold the height you are currently at. There may be some setting somewhere but since one scale will never "fit all", the "Pan to" seemed to be the route for me.
Gee! that sounds familiar
Joe Bouza
There is also the option of immediately after the "Zoom to" to do a Zoom Center, hit enter to accept the same center and change the height or just zoom and change the height or scale.
Allen
Allen Jessup
CAD Manager - Designer
Sorry Joe. Didn't intend to get credit or plagiarize. Now after re-reading your post I'm red faced. Must be the cold medicine. I now feel like pulling my hair and slapping my head as Chris Farley did when talking to Paul McCartney.
LOL
I'was busting. I don't want to make anyone feel bad.
All in good fun!
Cheers.
Joe Bouza
Does anyone know why my "zoom object" is no longer centering said object inside my viewport? Just switched over to 2018 so maybe that is part of the problem.
Good bug to report right there. I'm able to recreate it. Civil 3D 2018.2
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
