I am using Civil 3D 2013.
Trying to convert a tinn surface to a solid by selecting Solid pull-down inside the modeling woprkspace. From there, select Thicken. But once select thicken and select a surface, the command returns a message: "1 was filtered out, No surfaces selected". What am I likely doing wrong that I can not select my tinn surface and convert it to a solid with a thickness using the "Thicken" command?
Solved by AllenJessup. Go to Solution.
As you've found out. A Civil 3D Surface is not an AutoCAD Surface. So you cannot use AutoCAD Surface commands to edit a Civil 3D Surface. See this link. http://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticle...
Allen
Allen Jessup
Engineering Specialist / CAD Manager
