Up to now, I've been creating separate assemblies for the areas of my corridor that have superelevation. But, I've been thinking that I may not need to do that. Can I have all of my assemblies with the superelevation properties turned on? The corridor will only use that if there is a super in that area of my alignment, right? This would save a lot of time that I spend on creating separate "super" assemblies. Is there anything that I'm missing on this?
Thank you in advance!
Desirea
Civil 3d 2014
Solved by sboon. Go to Solution.
Ideally you can have one assembly for the entire road, unless you're dealing with intersections or other unusual circumstances. All of my assemblies are built with the superelevation parameters turned on. If I haven't applied a design speed and created superelevation then the assembly uses the default slopes instead.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
