Guys:
On the top menu bar, go pipes > Draw Parts in Profile View.
Then use the "s" option to select parts or just hit enter to put the whole network in profile view.
Sometimes it just doesnt like the network on top of alignments or linework even. I use this now, and it works 100% of the time.
Hope that helps.
It doesn't seem to matter how I add the parts, whether I right click on the part and click on "Add to profile view" or go to Pipes > Draw Parts in Profile View or even go to the Profile View Properties and check the boxes to add the parts. They still are not showing up and I get the same message "Object was of the wrong type....etc". The only solution I have found for this is to delete the part and create a new one which is a big pain when you have already designed your system. Please reply if you know a simpler solution to this problem.
Thanks!
Save file, purge file, audit file twice or three times, save file, close autocad completely.
Open file, audit file, save file.
Been a few errors I've corrected that way.
I call the method 'Punch and refresh' 😛
I think I have figured it out....The parts were not referencing a surface.....as soon as I referenced a surface for each part they started showing up in my profile views....
I think it is stupid that they have to be referencing a surface but apparently that was the problem....
That makes sense actually...can't tell you what elevation it is if you havent given it a surface. It should default to a surface if you had one in the file.
We just switched from 2009 to 2011 and just noticed this message also. I swear it was not there when doing my testing.
If I grip (ONE) object and RT-Click "draw parts..." I get:
1 object was of the wrong type.
All objects in the pickfirst set were filtered out, please select again.
If I grip (MULTIPLE) objects and RT-Click "draw parts..." I get:
Too many objects in the pickfirst set, please select again.
It WILL(for us) add the pipes to the profile view just fine, but is disturbing seeing the messages.
Changing pickfirst setting does not work.
I really don't think it makes much since that you have to reference a surface. why wouldnt you be able to manually set rim elevations that work with your surface and still see the parts on the profile view?
No, I understand completely the functionality of referencing a surface and most of the time I do. I just don't think that you should be forced to reference a surface if you don't want to. Like if you were going to set a manhole at an exact elevation for benchmark purposes. I know that you can set a reference surface and tell it not to dynamicly update with the surface and set your own elevation but why can't you just set an elevation without referencing a surface at all?
You can actually. I just set up a pipe network for a project very similarly.
The wierd thing is, you have to reference a surface first, then go back and take it out as the reference. Same with an alignment (though you have to edit the label style not to show stationing)
