Civil 3D Forum
"Ghosting" in paper space
2 REPLIES 2
neilyj666
447 Views, 2 Replies
Since installing SP1, I have noticed "ghosting" when panning/zooming in paperspace i.e. the original image is still visible. The only solution I have found is to turn off Hardware Acceleration and then turn it back on.
Has anyone else experienced this??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
2 REPLIES 2
LyleHardin
in reply to: neilyj666
Yes, we have a few machines around here that do that on occasion. We also have found turning off or on Hardware acceleration takes care of it.  All our machines are identical and it only seems to happen on some drawings. We've tried swapping video cards, re creating the viewports etc. Cycling the Hardware Acceleration seems to be the best solution. It's gotta be a video driver bug of some sort, I think.
ceethreedee.com
mm.. we have users with the same problem.
Hardware accelation on/off does work however we also found that if you change the layout regen options it works as well, plus its permanent. however switching to regen mode makes layout switching slower!
can't belive there is still no solution to this..
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Rail Community
