neilyj
Message 1 of 3 (175 Views)
"Ghosting" in paper space
175 Views, 2 Replies
01-09-2013 08:00 AM
Since installing SP1, I have noticed "ghosting" when panning/zooming in paperspace i.e. the original image is still visible. The only solution I have found is to turn off Hardware Acceleration and then turn it back on.
Has anyone else experienced this??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Mentor
hardin
Message 2 of 3 (173 Views)
Re: "Ghosting" in paper space
01-09-2013 08:06 AM in reply to: neilyj
Yes, we have a few machines around here that do that on occasion. We also have found turning off or on Hardware acceleration takes care of it.  All our machines are identical and it only seems to happen on some drawings. We've tried swapping video cards, re creating the viewports etc. Cycling the Hardware Acceleration seems to be the best solution. It's gotta be a video driver bug of some sort, I think.
ceethreedee.com
Message 3 of 3 (88 Views)
09-23-2013 11:18 PM in reply to: neilyj
mm.. we have users with the same problem.
Hardware accelation on/off does work however we also found that if you change the layout regen options it works as well, plus its permanent. however switching to regen mode makes layout switching slower!
can't belive there is still no solution to this..
Civil 3D 2014 (SP2)
Win 7 Pro x64 -DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680) -24Gb Ram
NVIDIA Quadro 2000 (1GB)
ceethreedee.com
