We have a set of drawings that get a "Drawing ID is not valid" whenever they are opened in Civil 3D 2010. These drawings were created in C3D 2009, and they do not have this issue in C3D 2009.
Anyone know what this issue is, and how to fix it? It's extremely annoying, because it pops up for every sheet in the set, and there's 40 sheets. So when I want to publish the sheet set, I have to sit there and hit "OK" 40 times. And since it takes about a half a minute to open each drawing, that means I have to sit at the computer for nearly a half hour, waiting for that dialog box for the first page, then hit OK, then wait for that dialog box for the second page, hit OK, then wait for the dialog box for the third page, etc. ad nauseum totum.
Map queries were involved, including some images being queried in from drawing data sources.
I opened and saved all the drawings, updating them to 2010 format, and the problem seems to have gone away. It looks like Map queries don't like having drawings that mix the 2009 and 2010 formats.
Well, I guess that problem didn't go away after all. It came time to print out this Sheet Set again - it's now up to 39 pages - and I get two "Drawing ID is not valid" error messages for every page. So I get to sit here for the next half-hour hitting "Close" twice for every page before it will print.
Pretty darn annoying.
I wish I had some idea what this error is, or why it appeared in C3D 2010 when it didn't exist in C3D 2009.
Never mind, guess I don't have to sit here hitting "OK" for the next half-hour after all...
Civil 3D crashed attempting to print the sheet set. This is looking grim...
Hah! Got it to print!
This plan set has an XREF - I'll call it XREF "A" - which includes another XREF - I'll call it XREF "B". XREF "B" is "attached" to XREF "A", and the XREF "A" is "overlayed" into the rest of the plan set.
I don't think XREF "A" ever got upgraded to 2010. So I opened up XREF "A" and resaved it. Then I printed the plan sheet while XREF "A" was open in Civil 3D. I did not get any "Drawing ID is not valid" error messages, and the entire plan set printed.
So I'm tentatively thinking that maybe this is related to some sort of 2009/2010 compatibility problem. Either that, or having the XREF open in C3D during the Sheet Set print somehow sidestepped the problem.
I have no idea what really happened. I'm just happy that I got the whole thing printed, and didn't have to resort to printing one page at a time.
Not sure if RecoverAll would have helped or not. Since it seems that possibly all files merely needed to be upgraded to 2010 in order for everything to work (I think...?), then RecoverAll might have solved it, too. I actually didn't try that command, since I have 30+ sheet drawings, and didn't want to try running RecoverAll on all of them. (As far as I know, there's no way to run commands like that on a Sheet Set, short of maybe scripting or other custom programming.)
Still not really sure about the underlying cause or solution, but as long as the problem is gone, I'm happy...
Yeah this won't help the invalid id but if you use recoverall the first time you open dwg's like this, all xref's are updated to the new version so it's just a work around to prevent the issue.
John Mayo
