I hate it when I open a tool pallette - like Layer Properties, or Toolspace - and I drag it to move it to a more convenient location, drag it a bit too close to edge of the AutoCAD window, and the F-ing thing docks. The only pallette that I ever have docked is the Properties tool box. This is the only one that is open all the time, the others I open and close as needed. I move them around without thinking about it, and when it automatically docks it startles me out of my rythem and makes me forget the next step I was going to do after moving the pallette. Sometimes I forget the why I was moving the pallette in the first place.
Is it really necessary to make me turn off "Allow Docking" for every single pallette I open, every single time?
Is there a system variable where I can set the default value of "Allow Docking" to off? I can then turn it on for the one pallette I want it on for.
BTW, I'm currently working in Civil 3D 2014.
Solved by AllenJessup. Go to Solution.
You can change it in the CUI:
Allen
Allen Jessup
CAD Manager - Designer
Your welcome. I had the same complaint and figured it out.
Allen
Allen Jessup
No. I haven't had a need to. I don't see it either. You could set RECOVERYMODE to 1 and only open the Recovery Manager if you want. But it would still be docked if you do open it.
Allen
Allen Jessup
