The delete option is not fast enough?
Your Name
Or the condensed versionEditFeatureCurve. It's funny that Help [in 2011] says the command supports 2D & 3D polylines and Lines. Since none of those support curves.
Allen
Allen Jessup
CAD Manager - Designer
Me too. Reading this board helps open them.
Your Name
OK. Is there a way to Straighten the curve without deleting it?
Allen
Allen Jessup
Tying to be helpful by testing a solution - I just crashe c3d and lost an hours worth of work
In any event, I think you can only straightne a FL that has been previously Smoothed, otherwise it delete curves.
Your Name
Very sorry about that Joe. I see you're burning the weekend oil too. I tried tracking down a couple of blogs that hinted you could use Pedit-Straighten. But you can't use Pedit on Featurelines.
I suppose you could explode the FL, Pedit it and turn it back to an FL. I ended up deleting the curve, adding a straight featureline and joining that back to the remaining segments.
Again. My regrets. No chance of recovering an Autosave file?
Allen
Allen Jessup
No worries, yes I have many backup.
Your Name
