When I want to switch over to a different layout/drawing setup, why will it not switch over. It won't even bring anything up in the quick view drawings. I am not sure what is happening but I am on a deadline and I am the only "CAD" person around. Long story short, I can't switch from one drawing to another. Won't even let me into model space.
It will actually pop up very quickly then just disappear. Kind of weird. Closing and opening does not work. I know they are in this particular drawing too!
More information may be needed. You did not tell what method you are using, or your version. Ver. 2014 you can pick tabs.
However, try "Ctl"-"Tab" keyboard combination.
Bill
You could also try to Restore down, move the drawing window and pick the other drawing. Probably the best option is to use SaveAll and close the program and reopen the drawings.
Allen
Allen Jessup
CAD Manager - Designer
