AutoCAD Civil 3D General Discussion
5 Kudos
Post 1 of 4
Quick Select Points
141 Views, 3 Replies
01-24-2014 09:35 AM
I am trying to use Quick Select and select a group of point by either point style or point label style.
I am using the =Equals operator and typing in the correct name, but nothing happens.
Anyone else having this issue?
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
Win 7 Professional - 64-bit
HP Z230
Xeon 3.20Ghz
24GB of RAM
Nvidia GeForce GTX 760
*Expert Elite*
908 Kudos
Post 2 of 4
Re: Quick Select Points
01-24-2014 09:52 AM in reply to: mikepo
Yep, QSelect has never worked using Styles. Which is one reason we added the BuildPointSelectionSet command to the Sincpac-C3D.
Jeff_M, also a frequent Swamper
Valued Mentor
36 Kudos
Post 3 of 4
01-24-2014 10:43 AM in reply to: mikepo
A workaound I see would be to put all the points needing selection into a point group.
Eric Collins, P.Tech.(Eng.)
Win 7 Enterprise SP1 64 bit
Intel i7 3770 @ 3.40 GHz
16 GB RAM
Civil 3D 2012 SP2
5 Kudos
Post 4 of 4
01-24-2014 11:00 AM in reply to: ericcollins6932
Yes, that was my ultimate goal.
The issue was the points I needed were mixed in among other points.
So I had a point label style assigned to the points I needed, and a different point label style assigned to the points I didn't need and was trying to do a quick select and delete the uneeded points.
Thus finding out that choosing the point style or point label style in quick select wasn't working.
I got it done the hard way, but was curious if others had the same issue with quick select.
Thanks for the input.
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
HP Z230
Xeon 3.20Ghz
24GB of RAM
Post to the Community
New Post
