I am trying to use Quick Select and select a group of point by either point style or point label style.
I am using the =Equals operator and typing in the correct name, but nothing happens.
Anyone else having this issue?
Yep, QSelect has never worked using Styles. Which is one reason we added the BuildPointSelectionSet command to the Sincpac-C3D.
A workaound I see would be to put all the points needing selection into a point group.
Yes, that was my ultimate goal.
The issue was the points I needed were mixed in among other points.
So I had a point label style assigned to the points I needed, and a different point label style assigned to the points I didn't need and was trying to do a quick select and delete the uneeded points.
Thus finding out that choosing the point style or point label style in quick select wasn't working.
I got it done the hard way, but was curious if others had the same issue with quick select.
Thanks for the input.
