I'm using Civil 3D 2013. I'd like to be able to select all of the spot grades that are using a specific style. I have tried using Quick Select to do this, but have had zero luck. Here are the parameters I've been using:
Apply to: Entire Drawing
Object type: Surface Elevation Label
Properties: Surface Spot Elevation Label Style
Operator: = Equals
Value: style_name
In the value box I paste in the name of the surface spot elevation label style. After clicking okay, it always says "0 item(s) selected". I've tried a few different style names (all of which are in use). I've searched the web and haven't really found any information about people using the quick select command for this purpose. Any thoughts?
Can your routine be tweaked to select a pipe then generate a selection set of all pipes using that style? If so, could the code be tweaked to select all pipes with a style name in the code. I want to create a ribbon button to select all pipes using that specific style to then send to the back of the draw order.
It's been a while since I was setting all this stuff up, but I believe the original LISP for this thread worked for pipe styles.
Are you certain the check box for include is selected?
Joe Bouza
